Sprinkler Control Wiring Re-connect (diagram) - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2009, 12:44 PM   #1
DIY'r
ScottR's Avatar
Sprinkler control wiring re-connect (diagram)
Not sure if this belongs in plumbing, landscaping, or electrical..
Hi Everyone,
I'm having a problem with my in-ground sprinklers. I just got them turned on for the first time this season (installed by previous h/o a few years back). Two of my zones worked fine, and two would not work. I traced all the water and electrical connections, and came up with this diagram:
The red, orange, green and blue lines are electrical connections. I left out the common wire (black) which connects to each valve. The system is 24 VAC. Valves A-C are in the front yard, and valves D-E are in the backyard.
As you can see, valve B needs to turn on in order for zone 3 or 4 to work.
The problem is that the leads on valve B were ripped out. The blue and green wires pass through the box in the front yard, and I'm pretty sure one of them was connected to valve B (they are spliced in that box).
If I connect valve B to the green wire, then zone 3 works and 4 does not. Likewise if I connect valve B to the blue wire, zone 4 works and 3 does not. So all the valves and water connections are OK.
How in the heck was valve B connected such that it would turn on when either zone 3 or zone 4 is on???
Aside from the common wire, the 4 wires in the diagram are the only ones hooked up at the sprinkler controller. The sprinkler controller is not capable of turning on 2 zones at once, so I cannot simply connect a new wire to valve B and have it turn on along with D or E.
Thanks in advance!
Scott
ScottR is offline   Reply With Quote
Old 06-14-2009, 01:11 PM   #2
DIY'r
ScottR's Avatar
Here's a couple of pics.. I don't know how helpful they'll be -- the wiring is a mess.
I currently have valve B hooked up to the blue wire, so zone 4 works. When I first looked at the wiring, the splices for the blue and green wires had no wire nuts.
The white wire is also common, tied together with the black @ the controller.
Box in front yard. From left to right: Valve A, B and C.
Box in back yard.
Full-size images, in case they make it more clear:
http://www.codecrunchers.com/scott/p...t_box_full.jpg
http://www.codecrunchers.com/scott/p...k_box_full.jpg
Old 06-14-2009, 01:25 PM   #3
DIY'r
ScottR's Avatar
UPDATE: I just whipped out my multimeter. Looks like when any zone is on, I get 24V between that zone's connection and any other zone. The zones that are off read 6 Ohms to each other.
So it seems that an off zone becomes a common connection.
If I hook up valve B to both the green and blue wires it should work. Does anyone see a problem with this? Don't want to burn out my controller sending current back to a zone connection.
Old 06-25-2009, 08:48 PM   #4
DIY'r
ScottR's Avatar
It's been raining nearly every day here since my last post, so I didn't get around to testing things until today.
Connecting valve B to the green and blue wires did nothing (valve B would not actuate). I'm not sure why, as I was still able to detect 24V between the 2 wires when either zone 3 or 4 was on.
Any help would be greatly appreciated.. Thanks!
PS - Sprinkler controller is Orbit model 57586. I can get pics of the wiring there later tonight -- my wife absconded with the digital camera.
Very similar to this:
Old 06-25-2009, 09:51 PM   #5
Kap
Mowing my life away.
Remove valve B.
Problem solved.
It serves no purpose that i can see.
Or leave valve B in place, and turn it on manually and leave it on.
Kap is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Wiring limit control on gas boiler uncleneiler HVAC 2 11-21-2008 02:54 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Does this wiring diagram work? beezlebub03 Electrical 7 05-05-2008 12:54 AM
