Splitting Copper Lines Myself? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2011, 10:25 PM   #1
Rewards Points: 198
splitting copper lines myself?
i'm installing a bathroom and i'm tempted to split the cooper line myself for a shower head. The instructions i've got is from video, looks easy enough
http://www.thisoldhouse.com/toh/vide...632426,00.html
however before diving in.. is this something many fellow DIY-ers have done?
additionally, i'm looking to draw water from the main pipes coming out of the hearer, (3/4) and was wondering how big should my split be for a shower?
thanks
edit: to add, one of my concerns is that the line i tap is right next to the floor joist, since it's a slow ceiling basement, i'll need to solder right next to the joist and drill holes to have the pipes run though, i'm a little scared of having a torch next to that much wood.. that's all.
vote4Pedro is offline   Reply With Quote
Old 05-15-2011, 06:51 AM   #2
DIY staff
Rewards Points: 7,174
Pedro----Soldering copper is not to difficult for most DIYers. Practice a bit first.
In the areas where burning down the house is a likely hood---consider using a Sharkbite fitting--
They are expensive but so is burning down the house--
Use metal to shield the wood from scorching---I find that electric box covers make handy,cheap shields---they have handy holes for temporarily screwing into the studs.
Oaty Easy Flow solder and Oaty paste flux (Red can) are my favorites.
I also use MAP gas because it heats the pipes faster and gets the job done faster .
----Ask away----lots of members have learned this skill---others will offer their experiences to you---Mike---
Old 05-15-2011, 09:26 AM   #3
Rewards Points: 198
thanks for the confidence boost.
now the real questions, i have a main 3/4 that's running out of the boiler that's feeding the entire house. i'm looking to connect a toilet and a shower on the same line after a split. so
1. how large should my line be for the split?
2. how large should the line be for the toilet and shower after they split?
3. potentiall i want to add a faucet for a small bar, does that change 1 and 2?
thanks
Old 05-15-2011, 05:57 PM   #4
DIY staff
Use a 3/4x3/4x1/2 T---1/2 inch will supply a typical bathroom---Multiple head shower mixers require 3/4"
If you are using a standard shower mixer valve then 1/2 inch is fine.
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 08:44 PM
Both Copper Lines Cool Beha HVAC 10 05-24-2010 06:39 AM
plumbing copper for HVAC refrigerant lines? Mike in Arkansas HVAC 9 03-21-2010 08:52 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 10:23 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 09:54 AM
