Split Cast Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2011, 12:55 PM   #1
split cast iron pipe
I have a 5ft piece of cast iron drain pipe in my wall that is cracked almost the whole way down. I was going to replace it with pvc pipe, but i'm worried about cracking the pipe even more. What can i cut the pipe with so it don't break.
lstroble97 is offline   Reply With Quote
Old 12-29-2011, 01:02 PM   #2
jproffer's Avatar
Rewards Points: 716
If I was going to get into it to replace 5 feet of it, I'd just replace anything I could reach with PVC.
But to answer your question, they make blades just for cast iron for a recip. saw.
jproffer is offline   Reply With Quote
Old 12-29-2011, 01:03 PM   #3
jproffer's Avatar
Rewards Points: 716
666 posts????
Yea, I don't think so.............ignore this post, it's only for my own peace of mind
The Following User Says Thank You to jproffer For This Useful Post:
plummen (12-30-2011)
Old 12-29-2011, 01:06 PM   #4
Thank you.
Old 12-29-2011, 01:11 PM   #5
Thanks guys I'm new to plumbing. I have a 110 years old house , and can't afford a plumber or a husband .
Old 12-29-2011, 01:14 PM   #6
a sawzall or a 4 inch grinder with a metal blade in it.
Old 12-29-2011, 01:26 PM   #7
jproffer's Avatar
Rewards Points: 716
I know some husbands that would say the same about their wives....guess it's all a matter of perception.
Old 12-29-2011, 02:29 PM   #8
MarginallyQualified
Rewards Points: 2,464
I used to have a sorta GF that fit this description.
Accommodations can be arrived at.
Old 12-29-2011, 02:52 PM   #9
Retired carpenter
I wouldn't want my lady try to cut a cast iron pipe with a sawzall and have the blade get pinched on her. At rental stores you can rent for a couple of hours a tool that breaks (cuts) cast iron neatly and easily. I don't remember the name, but it looks like a big wrench with a bycicle chain sticking out from it.
If it doesn't leak and is in a wall, we are talking about a vent. Ducktape can take care of that.
abracaboom is offline   Reply With Quote
Old 12-29-2011, 09:26 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
Soil pipe cutter, is one name its known by,, I would not recommend she use this either, lots of bad things can happen with any method she uses , best thing she can do is temporally seal it, save money call a plumber. If all goes well,, 2 cuts 2 no hub couplings 2 no hub adapters, 5 feet of pipe one and a half hour labor. That’s if all goes well.. should not be too expensive. And done correctly none of this pipe to pipe fernco garbage.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-30-2011, 09:24 AM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by Javiles View Post
Soil pipe cutter, is one name its known by,, I would not recommend she use this either, lots of bad things can happen with any method she uses , best thing she can do is temporally seal it, save money call a plumber. If all goes well,, 2 cuts 2 no hub couplings 2 no hub adapters, 5 feet of pipe one and a half hour labor. Thatís if all goes well.. should not be too expensive. And done correctly none of this pipe to pipe fernco garbage.
Not to mention I wouldn't recommend a soil pipe cutter on a cracked piece of cast iron either.
Journeyman Plumber
Old 12-30-2011, 07:49 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Ive seen more old cast iron crushed by snappers than Ive ever seen screwed up with a recip-saw
How big is the pipe?
Normally you shouldnt use pvc pipe in line vertically between 2 pieces of cast iron,the weight of the cast will damage pvc.
Cast iron and pvc also expand/contract at differant rates.
Can you post a picture of the pipe so we can have a better idea of what youre up against?
plummen is offline   Reply With Quote
Old 12-31-2011, 12:51 PM   #13
thanks everyone...cut out the old 4" cast iron pipe with my grinder and reciprocating saw . replaced with a pvc pipe . works great...no leaks . now have to sheet rock..lol
The Following User Says Thank You to lstroble97 For This Useful Post:
oh'mike (12-31-2011)
Old 12-31-2011, 01:17 PM   #14
DIY staff
Rewards Points: 7,174
Dang--You just get right to it and get the job done,don't you?
cast iron pipe tnhldtch Plumbing 2 11-13-2011 09:19 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Galvaized pipe to cast iron main. rosemonster Plumbing 0 01-04-2011 12:49 AM
Cast Iron Pipe Cutter? tinmanrob Plumbing 6 08-09-2010 07:29 AM
Leak in Cast Iron? Pipe under toilet... terrapin88 Plumbing 11 11-19-2009 05:54 PM
