Splicing Shark Bite - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2010, 10:28 AM   #1
Rewards Points: 133
Splicing Shark Bite
I need to splice a shark bite tee into a 1/2 inch copper water line to run water to my refridgerator. My thought is to cut the appropriate length of copper out then slide the shark bite into place. I believe I'll have some flex in the copper pipe but not much. Is this doable with the shark bite? Any hints would be appreciated. Thanks
Jack E is offline   Reply With Quote
Old 05-04-2010, 01:04 PM   #2
Household Handyman
Rewards Points: 1,408
"Is this doable with the sharkbite?" YEP. And you may not have to cut any piping out. Determine how much you think should be removed, determine if the ends of the line after cutting will open that much, and install the sharkbite. I would clean the ends of the line further back than the sharkbite "bites" for a good seal. I'm not familiar with the "sharkbite" fittings. I used "Legris" and "Presto" fittings for years in an industrial setting with much success on air and water lines. They all use the same principle of sealing and grabbing. David
Old 05-04-2010, 01:11 PM   #3
my understanding is the plastic inserts need to come out when using copper
The older I get the better I was
Old 05-04-2010, 01:15 PM   #4
Household Handyman
Good point Mr. Polk, but what are the plastic pieces for? As I said, I'm not familiar with the "sharkbite" fittings out there today. I still had rather solder copper or use crimp fittings. Just me. David
Old 05-04-2010, 01:17 PM   #5
the inserts are there for plastic piping
Old 05-04-2010, 01:45 PM   #6
Rewards Points: 133
Thanks for the info, it sounds like this should work for me. I am planning on running 1/4" cpvc off the tee to the fridge; should I leave the plastic insert inside the 1/4" opening but remove it from the other openings that the copper will go into? I'm going with cpvc rather than pex or copper. The space is kind of tight to sweat copper and I don't want to buy all the pex tools. Thanks
Old 05-04-2010, 01:57 PM   #7
not sure if they have it for 1/4" you need to check
Old 05-04-2010, 03:20 PM   #8
Rewards Points: 286
Why can't you use an icemaker kit. It comes with the appropriate sized plastic tubing and what I believe is called a saddle tee that clamps onto the 1/2 inch copper pipe and a threaded puncture mechanism that you screw down to punch a hole in the copper. Then you just connect the tubing. If you do use a sharkbite tee, they also make slip couplings that give you 2 inches of play if there is not enough give in your copper line.
Jim F is offline   Reply With Quote
Old 05-04-2010, 03:34 PM   #9
Military Mom of 4
Snav's Avatar
Sharkbites only come in 1/2" and 3/4" as far as I know.
For your fridge application you should use the saddle tee that Jim mentioned - it's made for that purpose and is the simplest solution to the issue.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 05-04-2010, 04:17 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
I recommend against a saddle tee, they are know future leaks.
Install your Sharkbite tee ( Personally I would sweat in a copper tee). Install a short stub of copper and terminate with a 1/2' by 1/4" compression stop. From the stop run 1/4' flex copper tubing to the frig.
Coastal South Carolina
Old 05-04-2010, 05:40 PM   #11
Military Mom of 4
Snav's Avatar
Unfortunately - so are shark bites.
Pick your poison, nothing is leak proof
Old 05-04-2010, 05:48 PM   #12
Rewards Points: 133
Thanks to all for the advice. I did a Web seach on the shark bite and found that they offer a tee that has two 1/2" openings with a 1/4" reduction. The flex copper idea verses the cpvc sounds like a workable option. I haven't used the saddle tee but it certainly sounds like it would be the easiest. I'll check in with our local plumbing supply to get a visual on the options. Thanks again.
Shark bite! Chuckwagon Plumbing 10 01-07-2010 09:23 PM
Shark Bite fittings carlymoto Plumbing 5 11-27-2009 10:31 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 02:01 PM
Anyone use Shark Bite? Good ? Bad? twilightcall Plumbing 9 01-14-2008 08:05 PM
plumbers shark bite fittings jburkeg Plumbing 9 11-12-2007 10:29 AM
