Splicing Pvc To Galvanized Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 05:21 PM   #1
splicing pvc to galvanized pipe?
Repairing water line in an old home where galvanized has burst. Is there an easy way to attatch pvc to an unthreaded piece of galvanized??
debbi236 is offline   Reply With Quote
Old 05-22-2011, 05:37 PM   #2
WDR
They make these I am not sure how good they are. Just slip the pipes into the ends and tighten the nuts. I do not if you can get the steel ones at hardware stores but i know some have the pvc ones.
WDR is offline   Reply With Quote
Old 05-22-2011, 09:37 PM   #3
Thanks I will look for that t the hardware store!
Old 05-23-2011, 07:47 AM   #4
WDR
pipe
Also remember that if you have galvinized pipe after you fix one section others will start to leak. You will eventualy have to replace it all.
Old 05-23-2011, 02:06 PM   #5
Rewards Points: 1,668
Is PVC only ok for cold water lines and not hot? I thought I saw that somewhere.
bob22 is online now   Reply With Quote
Old 05-23-2011, 03:57 PM   #6
WDR
pvc
I did not think of that. Yes I believe pvc is for cold only, you have to use cpvc for hot water.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
is it possible to use a compression shut off on Galvanized 1/2" pipe? Limit54 Plumbing 8 04-11-2010 09:24 PM
Galvanized pipe threads ae now smooth in one spot DJDD Plumbing 1 01-21-2010 05:58 AM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 10:37 AM
