Splicing Diswasher Flexible Ribbed Plastic Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2010, 07:24 PM   #1
Splicing diswasher flexible ribbed plastic drain line
Is there a non-leaking method for splicing the ribbed flexible drain lines used on most dishwashers? I need to extend the line a few feet, but the end of the line with the rubber connection fitting coming from the dw is cracked and I will have to cut off this end. I'm worried that the splice will leak because of the spiral ribbing.
dmwhite509 is offline   Reply With Quote
Old 05-01-2010, 08:24 AM   #2
Rewards Points: 1,442
Can a short length of copper pipe go into the rubber coupling (or into the ribbed hose) and be held in place with a hose clamp? (Depends on what sizes you can get) Then get a length of hose and more hose clamps to connect the other end of the short copper pipe to whatever you are connecting to.
Do not add "a couple of feet" to the drain line. This may overload the little pump inside the dishwasher.
Old 05-01-2010, 08:28 AM   #3
i dont like the coupling due to food build up. can you run a longer hose, chk with maker
The older I get the better I was
Old 05-01-2010, 03:21 PM   #4
My main concern with any type of splice (coupling) is that since the inside of the ribbed plastic drain hose is also ribbed, I don't think a smooth exterior coupling will keep the water from running around the spiral. I think I need a new hose, or some kind of coupling that actually threads into the spiral inside the plastic line. Problem is I don't know if that kind of splice part exists.
The total length of the drain line is under 10 feet, which the LG book says is OK.
Old 05-01-2010, 03:31 PM   #5
go to home center and purchase drain line in size needed from roll stock
kennzz05 is offline   Reply With Quote
Gas Line Extension - Can I use Flexible Pipe? MikeinBurien Plumbing 35 10-15-2012 12:58 PM
Flexible copper gas line wease Plumbing 6 04-09-2008 11:40 AM
Cutting Concrete for drain line Piney Building & Construction 2 12-01-2006 08:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
Main drain line lmanwarren Plumbing 1 04-06-2006 01:32 AM
