Old 12-07-2009, 03:16 PM   #1
Exclamation
Splicing ABS Black Vent Pipe
I had to replace a shower faucet apparatus which went well, however someone placed the 1 & 1/2 " vent pipe right behind the faucet in the wall. I had to cut the black pipe (8 to 10 inches) so I could replace the faucet. Neither the upper or lower pipe will budge so I can put pipe and couplings on the existing pipe. I've never ran across anything like this before. Do they make unions or what. Any suggestions. Again, neither pipe will budge and it's tight quarters. Thanks
Garfield is offline   Reply With Quote
Old 12-07-2009, 03:53 PM   #2
A "Handy Husband"
rjniles's Avatar
Use Fernco connectors (rubber sleeve with the SS clamps). Any home center or plumbing supply hose will have them. Fernco is a brand name and there are other suppliers.
rjniles is offline   Reply With Quote
Venting ponch37300 Plumbing 41 02-23-2013 11:37 PM
Will corrugated black pipe crush under weight? Tmaxx Landscaping & Lawn Care 2 07-26-2009 07:34 PM
Gas stove vent to gas pipe clearance? rbarr110 HVAC 8 06-17-2009 04:36 PM
iron vent pipe broken at fitting CCarlson Plumbing 3 02-18-2009 08:40 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
