Old 07-11-2005, 08:30 PM   #1
spinning sink faucet
I have an older style cast iron kitchen sink. The faucet is antique style (but brand new) with seperate handles for hot and cold water. The handles seem to have become loose. If you push too hard while turning off the water, the knobs will spin all the way around with out turning off the water. I cant seem to find anything to tighten when I remove the handles. Any ideas?
doddsm is offline   Reply With Quote
Old 07-11-2005, 11:28 PM   #2
Brand new! If you installed it you might want to go over you're install steps. Hopefully, you still have the literature and you could contact the manufacturer for help. There are so many types of faucets it's hard to determine the problem. Make sure the hot and cold valve bodies didn't loosen up.
plumguy is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 09:12 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-19-2007 12:26 AM
sink and faucet neo777 General Discussion 8 11-05-2006 02:34 PM
