Spin A Toilet 90 Degrees - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2008, 11:13 AM   #1
Spin a toilet 90 degrees
Is it possible to spin a toilet 90 degrees on the flange? It currently faces the door from the end of a long thin bathroom facing the kitchen and I'd much rather see it sideways screened by a low wall or vanity.
Cowgirl1088 is offline   Reply With Quote
Old 08-05-2008, 11:42 AM   #2
Custom Cabinet Maker
dont think so, you will have to move/change the flange maybe an adapter out there
skymaster is offline   Reply With Quote
Old 08-05-2008, 01:36 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Most toilet flanges need to be 12" on center from the finished wall behind the toilet (some are 10" OC).
IF you have the room, you can turn a toilet 360 degrees on a flange. The flange, closet bend and drain pipe don't care which way the toilet above them faces because the flush is going straight down and then in whatever direction the plumbing runs.
The issue is the layout of the wall(s) from the flange center.
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-05-2008, 05:28 PM   #4
Send a message via AIM to Marlin
It depends on the flange type. If it's a lead bend or brass flange you can't spin it.
Marlin is offline   Reply With Quote
Old 08-05-2008, 11:57 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
au contraire mon ami....
While true that you can't spin them, most flanges that I have ever seen have multiple places to mount the closet bolts, which are offset exactly 90 degrees from one another. (probably not a cast iron flange, though.)
Journeyman Plumber
Old 08-06-2008, 06:20 AM   #6
I've only seen one like that once. The only way for him to really know is to pull up the bowl.
Old 08-06-2008, 10:15 AM   #7
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Definitely depends on the flange type. The clearance is also a factor. If the toilet was installed correctly to begin with, spinning it 90 degrees will leave it really cramped on one side.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 08-06-2008, 10:46 AM   #8
Rewards Points: 1,910
Definitely cramped like mst says because the flange is very likely only 12" from the wall. Pretty sure code requires something like 15" to the side wall.
Old 08-06-2008, 11:25 AM   #9
Click on the link below and scroll down to ABS Flanges. This is the normal type flange configuration you will find on most Closet Flanges. Notice the two slotted holes. This is where the flange bolts secure the toilet to the flange. Most flanges are not movable (glued or attached to the piping). This would prevent the turning of the toilet. The distance from the wall to the center of the drain piping would also be a problem. Codes normally require 15" from any wall or cabinet to the center of the hole.
http://www.plumbingsupply.com/toiletflanges.html
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
why one toilet backs up and other does not Richmarti12 Plumbing 2 03-16-2008 03:22 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 02:34 AM
