Old 11-17-2012, 10:26 AM   #1
spigot shut off
i have ball valves on my 2 outside spigots. about 1' inside the wall. i am figuring that shutting off the ball valve and opening the spigot is all i need to do to prevent a broken/frozen pipe ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 11-17-2012, 10:30 AM   #2
spigot shut off
And make sure there's not a hose attached outside.
Old 11-17-2012, 10:36 AM   #3
spigot shut off
of course . do i need to drain the hose ? any problems leaving the hose outside ?
Old 11-17-2012, 10:41 AM   #4
spigot shut off
I'd play it safe and lay the hose out with nothing attached to the ends, roll it up to drain it and store it someplace.
Why leave it out in the cold and sunshine and have it degrading. Connect the two ends together so insects do not make it there home.
Old 11-17-2012, 07:39 PM   #5
spigot shut off
ok. i'l drain it and bring it in.
Old 11-17-2012, 07:40 PM   #6
spigot shut off
oh. i brought my power washing inside. so i don't have to worry about it freezing up.
Old 11-17-2012, 10:15 PM   #7
spigot shut off
Don't forget to open the little piss caps on the ball valves and make sure water drains out (sometimes the little rubber washer stays stuck to the valve even when you've unscrewed the cap.) It's best to remove the cap and make sure the drain hole is clear (a small brad nail or tack works).
Ishmael is offline   Reply With Quote
Old 11-18-2012, 10:06 AM   #8
spigot shut off
i just went and looked. there is no piss cap on the valve.
Old 11-18-2012, 12:47 PM   #9
spigot shut off
Called a stop & waste valve
hammerlane is offline   Reply With Quote
Old 11-18-2012, 01:18 PM   #10
spigot shut off
ok. mine is just a ball valve.
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 08:50 AM
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 01:29 AM
Outside spigot question... carpenter981 Plumbing 31 10-06-2011 10:28 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
