Space Required Above Toilet Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2011, 10:58 PM   #1
Space required above toilet tank
I am installing a one piece toilet and a sink and countertop which has a pork chop extending over the top of the toilet. How much space do I need to have between the top of the tank and the underside of the pork chop?:
Bailey005 is offline   Reply With Quote
Old 09-12-2011, 11:47 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you're looking for a code requirement, there isn't one.
The practical answer is : As much as possible.
If I go to a house with one of those, it's going to take me considerably more time and effort to work on your toilet, and i'm going to charge accordingly. (probably going to have to pull and reset the tank)
I'd say a good 3-4 inches above the lid is enough to get arms in there, and adjust things, replace the flapper, etc. If you want to be able to do any more than that without removing and resetting the tank, you need a good 6-8.
Journeyman Plumber
Old 09-12-2011, 11:51 PM   #3
Homerepairguy's Avatar
Rewards Points: 990
Have you thought about how you will replace the fill valve assembly in the tank when it goes bad?
Homerepairguy is offline   Reply With Quote
The Following 2 Users Say Thank You to Homerepairguy For This Useful Post:
plumber666 (09-13-2011), VIPlumber (09-13-2011)
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 10:55 AM
HELP!! Toilet leaking from sides of tank when flushed. teamcampreder Plumbing 17 08-01-2011 10:26 AM
Decorating Behind a Toilet Tank john4153 Interior Decorating 6 06-13-2011 12:47 PM
tighten Toilet Tank Bolts bmenzie Plumbing 5 10-03-2010 12:24 PM
Toilet tank to bowl issue. Possibly defective batch? Dr_Jim Plumbing 0 01-18-2010 06:44 PM
