Spa Tub Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2006, 12:15 AM   #1
Spa Tub Install
I'm installing a Spa tub in an alcove. The tub (an American Standard Cadet Spa) has four feet that you level with shims. I have to put Leveling Stringers on that should contact the tub but not support any weight. I shimmed the four feet with Cedar shims and my question is how much will the tub settle down when it is filled with water (around 800 lbs)? Should I place the Leveling Stringers tight to the tub or not? Is there a different type of shim I should use?
Thank You for any guidance you can give me.
atilla137 is offline   Reply With Quote
Old 09-09-2006, 09:29 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes use stringers
Ron The Plumber is offline   Reply With Quote
Old 09-09-2006, 10:00 AM   #3
Thanks but maybe a little more info...
My question was not should I use stringers, my question was and is will the cedar shims compress with the weight of the tub? Should I leave a gap between the stringers and tub to compensate for the cedar shims compressing? Or place the stringers tight to the tub?
Old 09-09-2006, 10:04 AM   #4
Journeyman Plumber
Cedar will compress, cedar is soft, set stringers tight to tub, we usally support the bottom with mortor mix.
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 02:23 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Plantation Shutters: Professional Install or DIY? SlaveToTheWife Remodeling 1 06-01-2007 02:27 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
