Old 11-20-2011, 03:39 AM   #1
Sound under house about every 15 mins
I am having a wierd problem where for the last couple months about every 15 mins I hear a sound that lasts about 8 seconds coming from under the house, like the sound of water in the pipe after a toilet is flushed. The problem is the sound follows the water line under the house but the toilets are not running. I have a pool and a timer for the backyard sprinklers, and I don't know if they have anything to do with the sound.
Thank you for any help you can give this poor lady.
Denise5667 is offline   Reply With Quote
Old 11-20-2011, 05:23 AM   #2
Super Moderator
check your water meter-----write down the number before you go to bed---and again when you get up.
If you are using water--start shutting down the different systems that could be using water all by themselves,---I would suspect a toilet----
Denise5667 (11-20-2011)
Old 11-20-2011, 05:35 AM   #3
Sump pump?
The Following User Says Thank You to DexterII For This Useful Post:
Old 11-20-2011, 07:36 AM   #4
Lightfoot's Avatar
just a guess, but it could be a toilet with a slow leaking flapper.
Lightfoot is offline   Reply With Quote
The Following 2 Users Say Thank You to Lightfoot For This Useful Post:
Denise5667 (11-20-2011), oh'mike (11-20-2011)
Tags
plumbing, sounds, water
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 11:58 AM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
