Soot On Top Of Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2010, 07:38 AM   #1
Soot on top of hot water heater
I just discovered black soot on the top of my hot water heater. I had never before seen that. It fans out surrounding the surrounding the duct work on top of it. Is that normal ???
t_bell40 is offline   Reply With Quote
Old 03-09-2010, 08:19 AM   #2
Chicago, IL
Michael Thomas's Avatar
You are spilling exhaust gases out of the draft hood.
It's not normal.
There are many possible reasons this could be happening.
If you post a wide angle picture of the entire vent run from the top of the water heater to the point where it exits the utility area (where the heater is installed) we may be able to suggest a possible cause.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Water Heater Troubles deadguydrew Plumbing 9 10-19-2008 09:30 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 01:51 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 09:37 PM
