Old 10-10-2012, 05:33 PM   #1
Some zones not working on my got water heater
Hi
I have a have a hot water boiler system with 5 zones. When I broke down and let my wife put on the heat in the bedroom it worked fine. Once again I tuned the thermostat to get the heat working and nothing is happening. I realized 2 zones worked just fine but the remainder (3) do not work. Everything looks fine in the boiler room.
Any ideas.
Melw365 is offline   Reply With Quote
Old 10-10-2012, 07:49 PM   #2
biggles's Avatar
standing at the zone valves you see the push bar on them that slides the 2 zones working there is no resistance go right over the other 3 if you feel a resistance as you push them over slowly there is no call from the stat or the valve has 24Vs to it but the motor is shot... remove the zone stat and just each zone not working to see if the non-working swing with a jump...
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
