Soldering Tub/shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2011, 08:13 PM   #1
Soldering tub/shower Valve
I am in the process of picking new fixtures for the tub/bath remodel and have a couple of questions. My existing valve I am replacing is soldered on, but I am noticing many of the new valves have threaded inlets? Can I solder a male piece onto these valves or am I better to find a valve assembly that is not threaded? Thanks. Heather
hdavis73 is offline   Reply With Quote
Old 01-23-2011, 08:49 PM   #2
Hi Heather,
I'd say pick the fixture you like most and then go from there. Whether the pipe is threaded or sweated into the valve, provided the job is done properly, either will work equally well.
VIPlumber is offline   Reply With Quote
Old 01-24-2011, 03:21 PM   #3
Thanks! Any tips when attaching the threaded piece? I know some sites recommend using the Teflon tape and others plumbers dope. Any help is awesome.
Old 01-24-2011, 08:46 PM   #4
2-3 wraps of tape and then a little dope. No dope on the first 2-3 threads though so as to not gum up the valve.
Old 01-24-2011, 08:53 PM   #5
Owner
LateralConcepts's Avatar
I like soldered fittings. If you're connecting to copper, you'll need to solder anyway. What's 2 more joints? Plus you're not breathing fumes of pipe dope when you try to solder your MIP adapters.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Can I use a mixing valve for tub/shower in a shower only application? jayp Plumbing 1 01-21-2010 08:37 AM
tub/shower combo valve zircon Plumbing 2 06-15-2009 12:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
