Soldering Paste - Good Or Bad ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2011, 12:37 PM   #1
Soldering Paste - Good or Bad ?
Hi,
Someone recently told me that when soldering copper pipe it is best not to use Soldering Paste, but that it is better to use liquid acid (which I have never seen).
He says the reason is that the paste stays on the pipe and continues to work as an acid and corrodes the pipe.
Has anyone ever heard of this ?
Thanks.
Mike Mike is offline   Reply With Quote
Old 03-04-2011, 01:53 PM   #2
Experienced
Jackofall1's Avatar
Never heard of that one, I would say if a joint is soldered correctly the act of sweating the joint would fill the void with solder.
Mark
Old 03-04-2011, 07:40 PM   #3
Never heard that in my 30 years of doing this, also worked in many places that have copper installed for 50 + years and I can't say I have seen any holes corroded through the piping.
Dougtheplumber is offline   Reply With Quote
Old 03-04-2011, 09:20 PM   #4
A guy once tried to tell me that the ink from a magic marker would eat through copper. And another time a guy told me if you had eaten chicken with your hands the grease would not let you get a good solder joint. Now I have seen fittings that were corroded because the plumber failed to wipe his joints, but that is usually superficial, just a pet peeve of mine.
broox is offline   Reply With Quote
Old 03-09-2011, 07:47 PM   #5
Rewards Points: 77
ive heard that to, i use regular flux all the time, but like he said above, you wipe the joint clean with a rag. you should do that anyway just for appearence sake. i use old denim jeans as a rag. same with the body oils on your fingers, or dirt on your gloves, lol just dont touch the joint if possible.
bryan1282 is offline   Reply With Quote
Old 03-09-2011, 09:59 PM   #6
I always use a wet rag after soldering to wipe the joints.
VIPlumber is offline   Reply With Quote
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Soldering question Polyknikes Plumbing 9 08-29-2010 09:58 AM
soldering pipe sourmash Plumbing 8 12-16-2008 03:27 PM
Recommendations for a good corded and/or cordless drill jimmyfloyd Tools 15 11-30-2008 12:20 PM
Looks like a good Christmas this year! leroyme Off Topic 6 12-23-2007 11:45 AM
