Soldering With No Shut Off Near - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 10:02 PM   #1
soldering with no shut off near
Im trying to install a new ball valve under my sink since the old one is leaking. my problem in that my hot water line runs all the way back to the hot water tank with no shut off in the line. there is a shut off on the cold water feed feeding the hot water tank but nothing on the hot side. how do i go about soldering in the new ball valve when theres water in the line. do i have to shut the cold water to the tank off and drain the tank to get the water out or is there another way. plumber once told me to stick bread in the line to hold the water back but i dont have much faith in that any help would be great
chris0914 is offline   Reply With Quote
Old 05-22-2011, 10:45 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Shutting off the cold water supply to the water heater shuts off the hot water coming out of it. Turn OFF the power or gas to the water heater first.
Open the highest hot water faucet in your house for air and then the drain at the bottom of the heater tank (attach hose). The pressure and the water in the line need to be drained down. You don't need to drain the whole tank, but you can't solder with water in the line.
Yes, you can use a small wad of white bread (no crust) to temporarily plug the water draining out of the line in order to solder it. I have done it many times. When you turn the water pressure back on, remove the sink faucet aerator to flush the bread out through the spout.
Another alternative, since the shut-off valve is exposed under the sink is to simply use a compression fitting valve (no soldering).
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
The Following User Says Thank You to Mike Swearingen For This Useful Post:
chris0914 (05-23-2011)
Old 05-22-2011, 11:40 PM   #3
Now would also be a good time to install a stop and drain valve on your hot water line, somewhere near your HWT. That way, the next time you need to do any work on a hot water line, you can shut it off and drain it at the same spot without having to shut down your HWT.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Help? Replacing water shut off valves frozenmama Plumbing 4 09-28-2010 07:17 PM
No main power shut off vab53 Electrical 26 06-12-2010 03:51 AM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
