Soldering Copper Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2010, 04:41 PM   #1
Rewards Points: 135
Is it perfectly acceptable to take off a fitting and solder a coupling to it, as opposed to going back and soldering to virgin pipe?
smata67 is offline   Reply With Quote
Old 05-17-2010, 05:21 PM   #2
Rewards Points: 1,442
Nothing wrong, except that it is more difficult to re-use a fitting or resolder to a length of pipe.
The solder residue from the previous time might be too bulky to fit the parts together.
For one reason or another, the joint made with re-used parts often develops oxidation inside during reheating and the solder doesn't seal the joint properly and it leaks.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Soldering Copper chimney flashing buzzymalone Roofing/Siding 10 08-10-2009 09:28 AM
Replacing galvanized with copper pipes. Twinvtec Plumbing 18 02-24-2009 09:53 PM
Burying exposed copper pipes ryan_s HVAC 1 11-20-2008 08:20 PM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 09:18 AM
