Soldering Copper Pipe In Tight Location- Help Needed Pics Included - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2012, 08:43 PM   #16
Rewards Points: 320
Hey Alan, I went home, checked it out and did not have access to the bonnet nut. This is an old sillcock so maybe it has a slightly different set up? I ended up just cutting the old sillcock out from the copper piping, and chiseling it away from the wall... it was cemented into the wall. I am just going to solder a new one in. I actually tried using a Gator bite (shark bite knock off) to temporarily attach the new sillcock to the copper pipe inside and it worked great, but then leaked after 20 minutes from the threaded side (one side of the gator bite was threaded to screw onto the new brass sillcock, and the other side was the push fit part). I used teflon tape to try to stop the leak from the threaded side, and that helped but didn't completely stop the leak. I'm guessing either I did something wrong, the gator bite was faulty, maybe it needed thread sealant and not tape, maybe I didn't tighten it hard enough, I don't know but it didn't work so I removed it and am just going to solder the new brass sillcock to the copper piping inside tomorrow. I didn't know you could solder brass to copper, but the instructions for the sillcock apparently say you can. Man, I suck at plumbing, this shouldn't be this hard
amodoko is offline   Reply With Quote
Old 08-10-2012, 09:01 PM   #17
Missouri Bound's Avatar
You need to replace that with a anti-spyhon type.
Do you want it your way or the right way?
Old 08-10-2012, 10:16 PM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Yep, you can solder brass to copper.
Plumbing is one of those things where you're only as good as the amount of practice you've had at it.
I commend you for trying, though.
I wanted to ask if the new one you bought allows access to the bonnet nut without removing the handle. That will make things easier in the future.
Journeyman Plumber
Old 08-11-2012, 03:19 PM   #19
Rewards Points: 320
Thanks Alan, hopefully as I gain experience with this stuff I will improve because right now I'm as shaky as a leaf with it, hahaha. But the new ones have a much better setup and make it easy to do repairs. Here are some pictures of them (I bought different sizes in case one size fit better).
The guy at the hardware store actually said these can't be soldered, and that I had to buy the copper ones, but I think he is wrong. I assumed they were brass, but they don't say "brass" anywhere on the package, so I got a bit worried he was right and I was wrong. But the instructions do say it can be soldered. Do they even make frost proof sillcocks that CAN NOT be soldered to copper pipe?
Soldering copper pipe in tight location- Help Needed Pics included-img_20120810_190252.jpg
Old 08-11-2012, 03:37 PM   #20
Doing it myself
Alan's Avatar
A lot of times, fittings like the ones on the end of those are set up for both soldering inside, and take an FIP fitting on the outside of it.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
amodoko (08-11-2012), oh'mike (08-11-2012)
Old 08-11-2012, 05:14 PM   #21
DIY staff
Rewards Points: 7,174
Look into the threaded end---It's brass.
Most often it's easiest to solder a length of copper into the inlet. ---a fitting will not clear the hole in the wall.
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 05:34 PM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 09:44 PM
First Time Soldering (Sweating) Copper. Rate Results suprvee Plumbing 4 10-15-2010 07:27 AM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 01:10 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
