Soldering Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2011, 06:56 AM   #1
soldering copper pipe
I cant get soder to connect pipe soder flakes off any suggestions?
77naoj77 is offline   Reply With Quote
Old 01-28-2011, 07:47 AM   #2
I assume this is in existing plumbing, with water??? If yes, the water MUST be fully drained or you will mever get the pipe hot enough. Even a small trickle will cool the pipe, and you will end up with a "cold solder joint" that will probably leak.
Joints(both pieces) have to be cleaned thoroughly-emory paper works well, and flux applied.
Apply heat directly to the joint, touch the solder to the joint but not in the flame. When the metal is hot enough, it will melt the solder(remove heat) and suck the solder into the joint. Go all the way around the joint, wipe off excess.
The Following User Says Thank You to Just Bill For This Useful Post:
Lightfoot (01-28-2011)
Old 01-28-2011, 07:51 AM   #3
Lightfoot's Avatar
Rewards Points: 272
clean both pieces being soldered really good with emery cloth, keep fingerprints off of the clean joints, apply good clean flux with flux brush. No water can be standing in joint-it must be completely dry. Heat copper really hot and let the hot copper (not the flame) melt the solder.
Just Bill-you're too quick!-(or maybe i need to learn to type with more than two fingers).
Lightfoot is offline   Reply With Quote
Old 01-28-2011, 10:18 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... Tell Us how you're attempting it, 'n We'll tell ya where you're going Wrong...
Old 01-28-2011, 10:24 AM   #5
Experienced
Jackofall1's Avatar
If you do have water in the pipe, a good ole trick is to pack bread in the piping on either side of the joint, this will allow enough time to take care of the sodering, and will flush away once the water is turned back on.
Another tip, put the heat on one side of the pipe opposite to where you are applying the soder.
Old 01-28-2011, 10:32 AM   #6
There are a lot of on-line tutorials on proper soldering procedures. Just search Google: "How to solder copper pipes".
amen2u is offline   Reply With Quote
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 06:02 PM
Replacing a section of copper pipe to a Gas Water Heater outlet Question F150dad77 Plumbing 4 10-07-2009 09:32 AM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
Soldering copper pipe gail synsteby Plumbing 14 03-22-2008 01:08 PM
