The Solder Or The Valve? HELP! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2012, 10:21 PM   #31
DIY staff
Rewards Points: 7,174
Sounds like it just popped loose from the thinset---
If you stepped on the unit while the thinset was wet--you probably compressed the mud and left a hollow under it--
Don't know an easy fix--lift it enough to push some more mud under it--press it into the mud gently--and leave it alone until the mud is set up---
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 10 11-08-2013 12:25 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
