Old 09-12-2008, 05:48 PM   #1
Floor Sweeper
Solder for hot water heating system
What kind of solder should I be using when sweating copper piping for a forced hot water system? The changes I will be making are near the boiler. I'm curious because this is the first time I have needed to solder together any water piping on a system like this. I've heard guys using 95/5 solder, instead of the normal lead free plumbing solder.
Thanks in advance.
junkcollector is offline   Reply With Quote
Old 09-12-2008, 06:19 PM   #2
My understanding is that you only need to use lead-free solder for potable water supply piping. For every other kind of piping, you can use lead solder, and that would include the copper pipe in hot water heating systems.
Since the heating system is a closed system, when soldering, make sure you allow some way for the heated air inside the pipe to escape. Otherwise you build up air pressure inside the pipe that works against capillary pressure trying to suck the molten solder into the joint. The result can be joints that won't take solder.
Nestor_Kelebay is offline   Reply With Quote
Old 09-12-2008, 07:09 PM   #3
biggles's Avatar
NO WATER in any pipes or isolated away from where your soldring........95/5 is fine with flux and steel wool to clean all the fittings.the most important connections are to the exsisting....no water,or black water residue when you solder there.
hot water and central heating wont work independently khanay Plumbing 2 07-12-2008 04:14 PM
over heating electric water heater Jetfuelman Plumbing 6 04-24-2008 10:41 PM
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 08:09 AM
I added a radiator to my system and now need to know how to refill enough water memovox2 HVAC 21 01-30-2008 09:27 PM
Steam heating system problems Need HELP smay0808 Plumbing 7 11-06-2007 12:17 AM
