Solder A Cap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2010, 12:20 AM   #1
Solder a cap?
Hi, just wondering if someone could help me with a plumbing situation. I just bought a house and the laundry room was upstairs. We moved the washer and dryer downstairs yesterday and hooked everything back up as it was all ready to go. Everything there works great. I've no idea how to undo the plumbing that has been done for the upstairs. The problem I encounter is the white plastic water lines that come from the upstairs connect to the line that goes directly into the water heater. I imagine I could take off the white plastic water lines but how do I cap off where they meet the copper piping that goes directly into the water heater. Would I solder a cap onto it? Would I run into any issues?
Thanks, Kevin
dc_talk22 is offline   Reply With Quote
Old 08-02-2010, 11:23 AM   #2
Just call me Andrew
Rewards Points: 1,020
Is it possible to take a picture of the area in question?
Andrew
secutanudu is offline   Reply With Quote
Old 08-02-2010, 01:39 PM   #3
Sure, I will take a picture and will try and post it today.
Old 08-03-2010, 07:31 AM   #4
57_Hemi's Avatar
Thanks, Kevin
Are there no shut-off valves installed behind the washing machine upstairs?
If so u could shut valves off and disconnect from there then DONE.... make sure you leave access to the valves (via trap door etc etc). You could even thread in caps w/ t-tape onto the shut-offs for extra security.
57_Hemi is offline   Reply With Quote
Old 08-03-2010, 08:39 PM   #5
Thanks for your help. My father in law came over and helped me take care of it. There was no shut off valve. We just cut the lines and put on metals caps. Thanks anyway.
Tags
copper pipe , solder
Silver solder on previous soft solder joints GPS10 Plumbing 2 01-27-2010 04:34 PM
joint solder problem redss Plumbing 6 08-09-2009 04:52 AM
How to solder 2mm nuts DIYCUB Plumbing 4 04-09-2009 11:06 AM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 08:59 AM
Solder for hot water heating system junkcollector Plumbing 2 09-12-2008 06:09 PM
