#1 |
Trim Carpenter
Solar Water Heater for Shop
I was wondering what type & brand Solar Water Heater you would recommend for my shop. I live in Central Florida and have a 28' x 45' roof side available. It is a metal roof & is properly supported (I over build everything). I was thinking a closed loop system into a exchanger tank but others say go to a open system w/potable water running through w/storage tank. I do not have a large demand for water out there but I dint want the expense of having a heater out there costing me money and I don't use the water. Would it be better to install a larger system and have a branch to the house for hot water? If I go closed system I can pump the hot fluid wherever needed to exchangers through zones or loops. I am open to any suggestions just seams a closed system would have more options like hot water and heat as well, I have NO pool nor do I want one.
Thank you in advance for any suggestions. |
| Tags |
hot water, solar, water heater ![]() |
| Display Modes | |
| Low hot water pressure | crebive | Plumbing | 38 | 02-26-2013 01:26 AM |
| Solar Hot Water Heater | DangerMouse | Plumbing | 41 | 01-03-2012 05:53 AM |
| Kitchen Faucet Cold Water Runs Hot | Mthrboard | Plumbing | 8 | 08-02-2009 07:59 AM |
| Natural Gas Water Heater Leaking from Release Valve Pipe? | psumike | Plumbing | 6 | 01-14-2009 08:18 PM |
