Solar Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2008, 03:24 PM   #31
Originally Posted by MdangermouseM View Post
ok, i saw those. i'm still leaning toward the simplicity of the pic in post #8. it gets hot pulled in when in use and keeps elec. as backup if cloudy and solar is not enough. either way, i believe it WILL cut my overall costs, be easy and fun to make and setup. still have the two questions.... permit needed? (most likely) and 180 degree copper fittings? are they out there? kinda like a horseshoe?
and what about burying those lines while it's open and i'm building? i can drop them straight down into the well pit, (won't freeze there either!) then underground into the new crawl space and up. but i need to be able to clean and drain them. hmmmm...
DM
Use soft copper and get a bender. No fittings at all except at the end.
If you bury it make sure it is insulated well. Don't want it cooling down and it will cool down fast.
Of course you know that on cold days you will actually increase your energy use, right? I guess I already said that.
I feel like a dog chasing his tail.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-17-2008, 03:31 PM   #32
the Musigician
DangerMouse's Avatar
how so? please elaborate. and will a bender give me tight 180 turns?
DM
Old 10-17-2008, 03:56 PM   #33
DIY
Rewards Points: 150
It will if it's a 180+* bender...
gp_wa is offline   Reply With Quote
Old 10-17-2008, 05:10 PM   #34
DM
Depends on what kind of a bender you get.
Ground temperature is about 55 degrees.
You are going to take that 55 degree water and put into a 45 degree environment. This will drop the temperature of the water to 45 degrees. You have lost 10 degrees of heat.
That is how your system is set up to work.
No saving at all.
Old 10-17-2008, 05:22 PM   #35
the Musigician
i'm sorry, what you say makes no sense. i open the insulated lid for the morning sun to heat the pipes.... how does that make for 45 degrees?
DM
Old 10-17-2008, 05:28 PM   #36
DIY
Rewards Points: 150
How about a few dark cloudy days?
Old 10-17-2008, 06:01 PM   #37
DM
I don't seem to be able to explain it to you so I will have to move on.
Old 10-17-2008, 06:32 PM   #38
the Musigician
gp, dark cloudy days is why i'm leaving it electric too. and freezing is why i still have not decided to leave it hooked up in winter. if i can get help figuring out how to, or simply figure it out myself, i will. i already pay next to nothing to heat, perhaps i can pipe some of that to the box and my well pit? hmmmmm
Marvin, feel free to comment or not, this is a free forum, and thankfully, we live in America.
tnkz to all for input.
DM
Old 10-17-2008, 07:28 PM   #39
DIY
Rewards Points: 150
Yeah, the electric back up will ensure you still get warm water in the house, but the water in the roof tank may get colder, not warmer, which means it will cost you more to bring the temperature back to to ground temperature, and then up to set point, in the main tank.
If you heat the water some before it gets to your main tank, it will cost less to heat it to set point.
If you chill the water some before it gets to your main tank, it will cost you more to heat it to set point.
I'll look for my crayons
Old 10-18-2008, 06:41 AM   #40
the Musigician
what roof??? it's going to be on my well pit cover (post #30) ...... and, "freezing is why i still have not decided to leave it hooked up in winter. if i can get help figuring out how to, or simply figure it out myself, i will. i already pay next to nothing to heat, perhaps i can pipe some of that to the box and my well pit" (post #38) .....
DM
Old 01-02-2012, 07:27 PM   #41
CPVC is rated 180f @ 100 psi
logical is offline   Reply With Quote
Old 01-03-2012, 04:53 AM   #42
the Musigician
....and? You lost me.....
DM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
