Soil Stack Help Please - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2011, 12:28 PM   #1
Question
soil stack help please
with a COMPLETE tear down of a 5' x 10' attached bathroom on a 100 plus year old house I am left with a 4 inch cast soil stack sticking out of the ground just outside of where the wall was.
when I rebuild can I go back with all pvc?
do I make the toilet the lowest connection?
with a bathroom this small with only a toilet, sink and bath tub, can all be plumed into the soil stack with a stack vent on top to go above the roof for vent? and can the kitchen sink also be attached the same way without another vent since it is on the other side of the bathroom wall and would be at most 6 foot away from the main soil stack?
thanks for any help!
treerat is offline   Reply With Quote
Old 03-26-2011, 06:19 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
when I rebuild can I go back with all pvc? -yes
do I make the toilet the lowest connection? yes if your wet venting
with a bathroom this small with only a toilet, sink and bath tub, can all be plumed into the soil stack with a stack vent on top to go above the roof for vent? yes if you do not exceed the maximum trap arm lengths.
and can the kitchen sink also be attached the same way without another vent since it is on the other side of the bathroom wall and would be at most 6 foot away from the main soil stack? probably not. Depends on your local code
Old 03-26-2011, 10:40 PM   #3
thanks for the help! gona be awhile before I get to plum, looks like I need to do some foundation work first. what a mess I have gotten myself into.
Old 03-27-2011, 08:07 AM   #4
Plumb or Die!
Sounds like you've been reading up on stack venting. With that style all drains connect one on top of another with the toilet the lowest fixture, and a single vent through the roof. Doesn't sound like the way to go for you. If that vertical drain pipe can go horizontal under the floor your options are fairly unlimited. You can wet vent the bathroom group, and carry the horizontal pipe on to the kitchen. The bathroom will have one vent pipe from the sink, and the kitchen will have another. Tie them in together for a single roof penetration.
Helps to know where you live so we can know what codes apply to your area. Good luck!
plumber666 is offline   Reply With Quote
replace cast iron soil stack munsonr1 Plumbing 4 02-03-2011 02:08 AM
Can I install a basement toilet directly into soil stack and without a vent? oaktowngrrl Plumbing 3 01-28-2011 12:42 PM
venting soil stack rb76 Plumbing 1 08-04-2010 12:30 PM
Replace outdoor cast soil stack with PVC/ABS crazychef55 Plumbing 1 01-15-2010 07:12 PM
Soil stack "cover"? DIYGmaLynn Plumbing 3 09-04-2006 12:23 AM
