Is This Softener Drain Plan Acceptable? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2013, 10:31 PM   #1
Rewards Points: 243
Is this softener drain plan acceptable?
There is an existing drain for a long gone softener made up of 1.5 inch ABS running off to the lower right. My plan was to reuse the existing piping and 2 90 fittings to reverse its direction to move it closer to the new softener location. Will this function as I think it will? There will be some kind of inspection as my township requires a permit for a water softener.
chemman is offline   Reply With Quote
Old 01-01-2013, 10:59 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Wheres your vent?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
chemman (01-08-2013)
Old 01-01-2013, 11:14 PM   #3
Rewards Points: 243
Yep, I was wondering about that. I've never seen a water softener drain that was vented, unless it was run to a pre-existing fixture. The closest vented drain is the washer drain upstairs, almost on the other side of the house. Hmm...
Old 01-05-2013, 10:26 PM   #4
Rewards Points: 243
try again
OK, so I took a look at a copy of the 2009 building codes and educated myself a bit. Below is what I believe to be more correct than the last attempt. And one more thing, should I bother with the wye-tee and clean out or just use a long sweep elbow at the bottom?
Thanks!
Old 01-06-2013, 08:15 AM   #5
Roofmaster
Rewards Points: 2,172
Whats with the running trap near the end of the three coming from the right? There isn't a toilet over there is there??? This main waste (If thats what it is) dosent make any sense to me. Why would you put a running trap there?
Old 01-06-2013, 08:34 AM   #6
Rewards Points: 3,130
My softener drain has no vent. Nor have I ever seen one that did.
Old 01-06-2013, 08:55 AM   #7
Roofmaster
Old 01-06-2013, 02:53 PM   #8
Rewards Points: 243
To clarify, in the lower left corner is the drain exit to the sewer. The four inch pipe running to the upper left is a vent that opens to air at the foundation of the house. The three inch pipe running to the upper right is the house drain. If that helps at all.
Old 01-06-2013, 06:04 PM   #9
Rewards Points: 243
So now that my house drain has blown your mind, how about getting back to my softener drain.
Old 01-07-2013, 07:55 PM   #10
Rewards Points: 243
Am I to assume that silence is passive approval?
Old 01-07-2013, 08:19 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 432
If the 4" is a vent, why not put a 4x2 sant in it up high and stick your ptrap there?
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
chemman (01-08-2013), plummen (01-07-2013)
Old 01-08-2013, 08:05 AM   #12
No, I would not assume that.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 01-08-2013, 04:15 PM   #13
Rewards Points: 243
I realize I could do that as well, but I thinking that working with the 1 1/2 pipe will be easier than disturbing the house vent. Plus I have that length of pipe from the old softener drain that I can reuse.
Good.
I'm not expecting someone to come along and give me a stamp of approval. I figured I'd lay my plan out for people to come along and poke holes in, which several of you have.
Old 01-08-2013, 07:36 PM   #14
Plumber
Rewards Points: 432
You have plenty of play in the 4" because of the 90's. It will look much cleaner tucked into the corner and it will shorten discharge pipe length.
The balls in your court...
Old 01-08-2013, 08:14 PM   #15
Rewards Points: 243
Good point...
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Water softener drain nicko Plumbing 1 12-07-2010 10:44 AM
Drain for Water Softener... Mr Ron Plumbing 9 10-04-2010 01:44 PM
how many turns is acceptable on toilet drain moegumble Plumbing 6 08-13-2009 11:28 PM
Water softener & Iron filter drain DSKUP Plumbing 3 02-17-2009 11:14 AM
