-   -   Is this softener drain plan acceptable? (http://www.diychatroom.com/f7/softener-drain-plan-acceptable-167986/)
chemman 01-01-2013 09:31 PM
http://i47.tinypic.com/nxt4dx.jpg
There is an existing drain for a long gone softener made up of 1.5 inch ABS running off to the lower right. My plan was to reuse the existing piping and 2 90 fittings to reverse its direction to move it closer to the new softener location. Will this function as I think it will? There will be some kind of inspection as my township requires a permit for a water softener.
Thanks:thumbup:
plummen 01-01-2013 09:59 PM
Wheres your vent?:wink:
chemman 01-01-2013 10:14 PM
Yep, I was wondering about that. I've never seen a water softener drain that was vented, unless it was run to a pre-existing fixture. The closest vented drain is the washer drain upstairs, almost on the other side of the house. Hmm...
chemman 01-05-2013 09:26 PM
try again
OK, so I took a look at a copy of the 2009 building codes and educated myself a bit. Below is what I believe to be more correct than the last attempt. And one more thing, should I bother with the wye-tee and clean out or just use a long sweep elbow at the bottom?
Thanks!
http://i48.tinypic.com/33aap2c.jpg
jagans 01-06-2013 07:15 AM
Whats with the running trap near the end of the three coming from the right? There isn't a toilet over there is there??? This main waste (If thats what it is) dosent make any sense to me. Why would you put a running trap there?
md2lgyk 01-06-2013 07:34 AM
My softener drain has no vent. Nor have I ever seen one that did.
jagans 01-06-2013 07:55 AM
:whistling2::whistling2::whistling2:
chemman 01-06-2013 01:53 PM
To clarify, in the lower left corner is the drain exit to the sewer. The four inch pipe running to the upper left is a vent that opens to air at the foundation of the house. The three inch pipe running to the upper right is the house drain. If that helps at all.:huh:
chemman 01-06-2013 05:04 PM
So now that my house drain has blown your mind, how about getting back to my softener drain.:wink:
chemman 01-07-2013 06:55 PM
Am I to assume that silence is passive approval?:(
TheEplumber 01-07-2013 07:19 PM
199 Attachment(s)
If the 4" is a vent, why not put a 4x2 sant in it up high and stick your ptrap there?
md2lgyk 01-08-2013 07:05 AM
No, I would not assume that.
chemman 01-08-2013 03:15 PM
I realize I could do that as well, but I thinking that working with the 1 1/2 pipe will be easier than disturbing the house vent. Plus I have that length of pipe from the old softener drain that I can reuse.
Originally Posted by chemman http://www.diychatroom.com/images/buttons/viewpost.gif
Good.
I'm not expecting someone to come along and give me a stamp of approval. I figured I'd lay my plan out for people to come along and poke holes in, which several of you have.:thumbup:
TheEplumber 01-08-2013 06:36 PM
199 Attachment(s)
You have plenty of play in the 4" because of the 90's. It will look much cleaner tucked into the corner and it will shorten discharge pipe length.
The balls in your court...
chemman 01-08-2013 07:14 PM
Good point...
