Softener Drain Options - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2011, 08:24 PM   #1
Rewards Points: 97
softener drain options
new home, need to softener, problem- the laundry sink is one floor above (distance from softener= 10ft vertically & 10ft horizontally) and the sever standpipe is not readily accessible. sump pit (advice on this forum) is not a good idea. so...
questions-
1. is the laundry tub too high & far? (no help in installation guide)
2..are there pumps (like a/c condensate pumps) that can be used? i did some search but did find anything.
3. what are the other options
thanks
drgkjd is offline   Reply With Quote
Old 12-14-2011, 08:06 PM   #2
Rewards Points: 133
All I can tell you that an AC condensate pump will not be able to handle the volume from a backwash. Isn't there any drain pipe in your basement that can be used?
paul100 is offline   Reply With Quote
Old 12-14-2011, 11:03 PM   #3
Try sending it to your storm drains.
VIPlumber is offline   Reply With Quote
Old 12-15-2011, 11:16 AM   #4
Rewards Points: 3,130
When I installed a softener, I tapped into one of the drain lines in my crawl space, installed a trap, and ran a standpipe up through the floor right next to the softener. The softener installer put an air gap on the standpipe but that's not really necessary. It's no different than a washer drain standpipe.
The Following User Says Thank You to md2lgyk For This Useful Post:
drgkjd (12-15-2011)
Old 12-15-2011, 05:05 PM   #5
Rewards Points: 97
i can do that.. but is it code-acceptable?
Old 12-15-2011, 08:34 PM   #6
Rewards Points: 582
you can check with local officials we did something like this awhile back they were ok with it....
The Following User Says Thank You to ben's plumbing For This Useful Post:
drgkjd (12-28-2011)
Old 12-15-2011, 11:53 PM   #7
Around here the storm and sanitary drains are run completely separate. The sanitary drain water is treated before it's released and the storm water is not. Our local AHJ's (Authority Having Jurisdiction, aka local gov'ts) do not want to have to treat this extra/excess water and therefore have mandated that it's run to the storm drains.
As to whether it's acceptable in your locale, only your local city/county inspectors can accurately answer that question.
The Following User Says Thank You to VIPlumber For This Useful Post:
drgkjd (12-28-2011)
Incomplete softener flushing dadaddio Plumbing 59 01-02-2014 07:03 PM
Central Air Secondary Drain Leaking - 3 questions walters_12 HVAC 7 05-11-2011 04:20 PM
water softener drain gccrafty Plumbing 3 08-04-2010 06:20 PM
water softener drain line moreira85 Plumbing 6 10-31-2009 01:14 PM
Frozen Garage Floor Drain Dragon General DIY Discussions 8 01-25-2009 07:07 AM
