Softener And Acid Neutralizer Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-29-2010, 03:17 PM   #1
Rewards Points: 160
Softener and Acid Neutralizer Connections
Check out this kludge that the previous HO used to connect the backwash waste lines from the water softener and the acid neutralizer! (I swear I didn't do that!)
Well, it finally started to leak. My questions:
1. I did a short term fix by reconnecting only the softener line with a 1/2 inch male-male nipple to connect just the tubing that comes up from the bottom and out the top. Any thoughts on the right way to connect that gray hose? It looks like it clamps over a 3/4 inch pipe in that kludge.
2. Should there be backflow preventers? I mean when one of them backwashes is the back pressure harmful to the other?
Thanks!
cgoll is offline   Reply With Quote
Old 10-29-2010, 04:06 PM   #2
Water Treatment
Rewards Points: 850
If it is possible run two lines , one for each to the drain, if not possible then a check valve in each of the lines will work.
Akpsdvan is offline   Reply With Quote
Old 10-29-2010, 07:09 PM   #3
With a properly operating valve on the softener and Acid Neutralizer a separate backflow preventer is not necessary. The valve on softener and the neutralizer prevents backflow into the respective unit. If the valve on either fails the results are typically not serious so the benefits of a separate backflow preventer are minimal.
A downside of backflow preventers is that they introduce some backpressure into the drain system--typically not a problem but not desirable either.
Bob999 is offline   Reply With Quote
Acid Neutralizer Issues Elamcup Plumbing 12 05-21-2010 08:09 PM
