Soft Tub Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2011, 12:00 AM   #1
Angry
Soft Tub Floor
Well I have been in my home for about 7 years now. Over that time (college etc) had many roommates and never personally used the guest bath. Now that things have changed (graduated/worked/married) I decided to check it out only to find that the tub floor feels soft, rotted, and is holding a puddle of water after showering. Got under the house and checked out the joist and subfloor to see that there is no rot or damage. How would one go about repairing/reinforcing a tub floor in such a case?
Note* It looks like the original contractor/builder used simple foam insulation to secure the floor. this is no longer holding the weight......
House was built in '92
jimreed02 is offline   Reply With Quote
Old 03-18-2011, 07:20 AM   #2
Fiberglass tub??? They usually need support under them when installed. Either the support was never installed and the tub has weakened, or the support is deteriorated. Urethane foam injected under that area might help, but I suspect it is time for a new tub.
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 07:49 PM
Fixing a soft spot in the floor kat26 Flooring 1 05-19-2010 08:36 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
