Soft Copper Pipe Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2013, 05:41 PM   #1
soft copper pipe issues
It's Easter Sunday, we're at my Mom's anyway so I decide I'll replace the toilet since I bought it six months ago and haven't had the time to replace it.
The shutoff valve is no good, so I turn off the water and cut the valve off. As I'm cutting, the pipe deforms and I realize that she has malleable soft copper pipe in the wall.
I can't seem to cut it without deforming it and it appears even after I clean it up it is still a bigger OD than standard 1/2" copper pipe so there's no way I'm going to get a 1/2" fitting on there.
Long story short, I cleaned the inside of the pipe, fluxed it, banged it flat and soldered it shut so I can could turn the water back on. i traced the soft copper to a 3/4' supply with a tee, so next week when I have the time I will cut out the tee and install new piping. If I didn't have the knowhow to bang the pipe closed and sweat it, she would still have no water.
If I had the knowhow on how to deal with soft copper pipe, she would be fine.
What is the best way to cut it without deforming it? It is really soft.
Is the OD of soft copper different than the OD of type M?
As I said, I am going to cut it all out and replace it anyway, but I'm wondering what my options were.
(I also violated my own rule of never ever starting a plumbing job after hours or on a holiday when the stores are closed.)
fred54 is offline   Reply With Quote
Old 03-31-2013, 05:48 PM   #2
Rewards Points: 13,300
Got a picture?
Why did you not heat it up to remove the old shut off instead of cutting it off?
Then you could have used a compression fitting.
A dull cutter is a sure way to crush the tubing.
Old 03-31-2013, 05:52 PM   #3
DIY staff
Rewards Points: 7,174
Soft copper requires a very sharp tubing cutter----and a gentile hand---many turns --shallow cut--
try the job with a good cutter----
COLDIRON (04-02-2013)
Old 03-31-2013, 06:02 PM   #4
I didn't heat it up because I am an idiot. I guess if I change my cutter wheels I wouldn't have malformed the pipe.
That does answer my question about the OD being the same for soft and for hard though and I do appreciate that.
Thanks as always!
Old 03-31-2013, 06:10 PM   #5
DIY staff
Soft copper os a challenge--the OD is the same---consider a 'shark bite' shut off valve of you have trouble next time---I've never used one---but the members here have never mentioned a failure---
Old 03-31-2013, 09:31 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 452
soft copper is available in 1/2" od and 5/8" od
5/8" is also the od of standard hard drawn copper pipe K,L & M pipe are all the same od
Old 04-01-2013, 03:13 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
And for what it's worth, I wouldn't use any type M on a domestic water system. Type L minimum.
Old 04-02-2013, 06:53 AM   #8
Rewards Points: 1,216
I second that.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
How To Bring Copper Pipe Through Concrete Block Starlight Plumbing 14 12-15-2012 08:48 AM
Bent soft copper pipe slkarns Plumbing 3 05-05-2012 12:00 AM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 09:22 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 07:38 PM
