02-02-2013, 09:05 AM
#1
Soderless copper fittings
A friend of mine is doing the glass doors on a shower. So he is checking out the guys plumbing and he tells me that they used some sort of copper fittings that are solderless. I tell him sharkbite fittings. The way he is describing them he claims they are copper with a little ridge along the edge. Are there copper sharkbite fitting? The plumber is licensed, it is a very high end bathroom. I am thinking that the plumber is just not dripping solder all over the place and my friend thinks it looks funny.
02-02-2013, 09:23 AM
#2
Remodeler
Most likely they were pre soldered fittings
http://www.presolderedfittings.com/
02-02-2013, 09:38 AM
#3
Pro Press compression fittings is my guess.
The Following User Says Thank You to jlmran For This Useful Post:
02-02-2013, 09:40 AM
#4
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
02-02-2013, 05:11 PM
#5
I showed him the links, it is one or the other. He thought they were pushed together and heated. The only reason we could think for using this type of fitting was for a time saving factor. These must have come around before the sharkbites. Personally I would not put these types of fittings in an enclosed space
02-02-2013, 05:45 PM
#6
Average Joe/ex-Navy IC3
Shark bites are fine in an enclosed space, when properly installed. They work just as well as soldered or crimped fittings. Personally I find that the Shark Bites are quicker to install, and pretty much dummy proof, that even a five year old could install them.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
02-02-2013, 06:20 PM
#7
Doing it myself
That's funny, because I went behind a guy I work with on a job where he patched some copper with a piece of pex and 2 sharkbites (lame, I patch copper with copper. <_< ) and the pex stiffeners were both completely crushed inside of the sharkbites. I'm surprised the poor lady was getting any water at all through that mess.
Journeyman Plumber
02-02-2013, 06:23 PM
#8
Doing it myself
P.S. : I don't consider those pre-soldered fittings to be any sort of time saver what so ever. You still have to measure, cut, ream, clean, flux, support, and heat the joint. The solder is already in there, so you're merely taking a 2 handed operation and making it a 1 handed operation.
Journeyman Plumber
02-02-2013, 06:34 PM
#9
call me E
Totally agree- but what homeowner wants to pay over $20 for a roll of solder
02-02-2013, 06:48 PM
#10
That would be because the idiot did not use the insert that goes inside the PEX, before you place it inside the Shark Bite. Keep in mind, that real Shark bites have the insert already as a part of the piece, off brands have them in the bag, or you have to purchase them separate. Also the person buying them, needs to make sure that they state they are for PEX, not just CTS, CPVC, Copper
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
