05-29-2012, 05:32 AM
#1
Soaker Tubs - Sizing
What is the standard dimensions for a full-sized soaker/jacuzzi tub?
Is it 6' x 4'?
What about standard tubs? Are those 5' x 3'?
05-29-2012, 10:30 AM
#2
Doing it myself
They come in a variety of sizes, depending on what options you want, and how much money you want to spend.
60, 66 and 72 are standard lengths
Widths are available anywhere from 32, 34, 36, and 42.
Again, it depends on what tub you are getting.
Journeyman Plumber
05-29-2012, 09:36 PM
#3
my bad Iam brain dead...
05-30-2012, 05:54 PM
#4
So those are actual dimensions of the tub, not "rough in" dimensions?
05-30-2012, 06:09 PM
#5
This is correct
05-30-2012, 08:01 PM
#6
Super Moderator
Tubs size is also the rough framing size--tubs are installed to the studs--then wall covering is installed--
05-30-2012, 10:16 PM
#7
Doing it myself
Note that rough framing is generally 1/8 - 1/4 " larger than the tub itself to give space for minor imperfections in the tub flange.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
05-31-2012, 07:11 AM
#8
Super Moderator
If the situation will allow it---leave one end wall unframed until the tub is in place---
This can make the job much easier---add the wall after the tub is in the opening--
06-02-2012, 02:16 AM
#9
I might get a "freestanding" instead of a drop in as they utilize space better.
Can't leave any walls "unframed" as the walls are ICF/concrete walls.
06-02-2012, 11:13 AM
#10
Doing it myself
If the walls are ICF, then i'm betting the floor is concrete. Most freestanding tubs are designed for the valves to be mounted to the side of the tub with the waterlines coming out of the floor. Most of them require a wood floor in order to make the connections below the floor after the tub is set.
We did one on a concrete floor just recently because the owner insisted, and I can't believe it actually worked. When I compared our method to the installation manual, we pretty much did everything completely backwards.
Journeyman Plumber
06-03-2012, 12:44 AM
#11
Yep, the floor will be concrete (InsulDeck).
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
