So Much Glue (rant) - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2015, 12:00 PM   #1
Rewards Points: 736
So Much Glue (rant)
I wish I had taken a picture before tossing the thing.
I re-caulked my shower / tub this past weekend, and when I got to the tub spout I realized when I removed the caulk there was a gap around where teh spout met the wall. The gap was filled with glue. Not any kind of silicon caulk, but a thick, hard, yellow GLUE.
This was a twist-on style spout, so it was screwed onto a threaded end of pipe coming out of the wall... but I couldn't see that, because the thing wouldn't BUDGE with all of the glue. I spent almost an hour picking and chipping away at the glue before I was comfortable that the spout was twist-on (there was a hole at the bottom for a set-screw, so I thought it might be a slip-on type) and just kind of brute force unscrewed it (not easy, even after removing a bunch of the glue).
Removing the threaded piece of the pipe and putting on a slip-on spout took ten minutes (after cleanup of all the mistakes of the previous homeowner) and less than ten dollars. Why can't people do things right the first time?
TheBobmanNH is offline   Reply With Quote
Sistering beam question, what outdoor glue? maxim1 Building & Construction 12 07-11-2014 05:29 PM
Wood Floors - old glue, something a little different scootermcrad Flooring 13 11-11-2012 06:36 AM
To Glue or Not To Glue denvermatt Carpentry 9 08-22-2011 09:21 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 08:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 10:12 PM
