Old 01-27-2008, 05:42 PM   #1
So I searched and read
through the forum and I think I have a game plan. Basically the problem is when the toilet is flushed and then the bath sink is turned on water is leaking
from the vent pipe. I want to cut the vent just above where the two arrows are, remove that section from the cast iron and use pvc to repair the section. Any suggestions?
shimmy25 is offline   Reply With Quote
Old 01-27-2008, 05:51 PM   #2
Union HVAC Tech.
Call a plumber, lead work isn't a DIY repair unless you have done it before and know what is going on.
bigMikeB is offline   Reply With Quote
