Snap Cutter Not Safe On Old Cast Iron Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2012, 05:41 PM   #1
Rewards Points: 682
Snap cutter not safe on old cast iron pipe?
I just opened up the slab under my shower and am looking at 2" cast iron pipe and trap (I think it is 2", it is @ 2.5" across). I'm thinking about renting a snap cutter to remove it but I've heard snap cutter can crack or otherwise damage old pipe. I need this pipe intact.
Is it too risky to use a snap cutter? I know they are fast.
darsunt is offline   Reply With Quote
Old 11-07-2012, 05:54 PM   #2
Fastener Fan
AirKingFS's Avatar
One user here mentions that a hacksaw can be a safe option.
http://wiki.answers.com/Q/How_do_you_cut_cast_iron_pipe
AirKingFS is offline   Reply With Quote
Old 11-07-2012, 05:59 PM   #3
DIY staff
Rewards Points: 7,174
If the pipe is so rotten that it crushes instead of snaps---then it need replacing any ways----
If you decide to try a saws all---get cast iron cutting blades----you may need to go to a plumbing supply--
An angle grinder does a nice job cutting cast----I've even made cuts with a diamond grinder blade when that was all I had---odd--it didn't wreck the blade---
Old 11-07-2012, 06:54 PM   #4
Rewards Points: 12,856
Snap cut is the best way, cleanest cut, no sparks or powder that will rust anything it touches.
Is this XH or SVC Grade Cast Iron Pipe? vrflp Plumbing 2 10-23-2012 11:28 AM
Putting PVC to cast iron tub and pipe Jamason Plumbing 2 03-26-2012 07:39 PM
Build up in cast iron pipe bend -> new high pressure toilet to fix? VTJeff99 Plumbing 3 02-09-2012 02:05 PM
Cast Iron Pipe Cutter? tinmanrob Plumbing 6 08-09-2010 08:29 AM
cast iron drain pipe? sharp Plumbing 3 10-14-2009 12:52 PM
