Snake 101 - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2013, 09:18 PM   #1
Rewards Points: 506
Snake 101
Shower drains slowly. Wife has long hair. 2+2=4. So I retrieve my homeowner-grade snake (from Lowes) and get to work. I retrieve a decent hair-bomb. I say, "Awesome...easy fix." During the cleanup using the shower-head I notice that the water now drains MORE slowly. I think to myself, "must have only retrieved part of a larger hair-bomb". I go back in with the snake. So here is the question:
I can feel the snake make it to the trap. I feel it make the first bend. Then...it hits something HARD. And I can't get it to go any further. I wiggle...I twist...I shove...I fume...I cuss...and so on.
What am I doing wrong? Anything? I can shove 10 feet of snake through the other bathtub drain in another room. But there is something about this shower drain that is beating me. Can only go about 1-2 feet. My worst case scenario fear is that the drain has collpased or failed in some manner. House is on a slab...no underneath access. Thoughts?
jlmran is offline   Reply With Quote
Old 03-21-2013, 10:15 PM   #2
Rewards Points: 2,030
Reverse and forward the snake. What type of pipe are we dealing with?
Ghostmaker is online now   Reply With Quote
Old 03-21-2013, 10:32 PM   #3
Rewards Points: 506
Pvc.
Old 03-21-2013, 11:35 PM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
I know, silly question but...have you tried plunging it yet?
fetzer85 is offline   Reply With Quote
Old 03-22-2013, 07:30 AM   #5
Rewards Points: 506
Nope.
Old 03-22-2013, 08:23 AM   #6
Always learning...
fetzer85's Avatar
Rewards Points: 262
My father-in-law cleared some type of obstruction from their basement shower drain w/ a plunger so it may be worth the minute or two to give it a shot.
The Following User Says Thank You to fetzer85 For This Useful Post:
jlmran (03-22-2013)
Old 03-22-2013, 09:43 AM   #7
Rewards Points: 352
put a bend in the first 1-2 in. of the cable. it will be easier to make the bend
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
jlmran (03-22-2013)
Old 03-22-2013, 07:52 PM   #8
Rewards Points: 506
Well I think the plunger would have worked. But I didn't get to try. I was taking a shower and standing about ankle deep in water. That much water must have been heavy enough...because all of a sudden...ka-whoom!!...down goes the water. Drains great now.
Thanks for all the suggestions.
Old 03-22-2013, 08:16 PM   #9
Always learning...
fetzer85's Avatar
Rewards Points: 262
Glad to hear. You removing that first hair bomb must've opened the gates to the (presumably) second one.
Old 03-22-2013, 08:42 PM   #10
Roofmaster
Rewards Points: 2,210
If it happens again, use the force pump (Plunger) but fill the shower pan with water first. This makes the force pump work like a piston with a check valve and you can really get some pressure on the clog, otherwise you will just draw air, which is compressible.
Can't get snake down tub overflow darsunt Plumbing 15 11-10-2012 08:50 AM
Tub drain completely blocked. Snake no help. Sink and toilet fine. Whybenormal Plumbing 10 08-01-2011 10:55 PM
Snake Identification Giles Off Topic 1 06-05-2010 02:37 PM
Stuck Snake frederick70 Plumbing 22 05-13-2009 05:01 PM
How to use a snake to clear a drain? Nestor_Kelebay Plumbing 11 12-09-2008 04:45 PM
