Smell From Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2009, 02:36 AM   #1
Smell from water lines
Just bought a 6 year old house. It has been empty for 9 months. It has copper plumbing. The water has a strong rotten egg smell. I have run the water for several hours and it still smells. What can i do? Thanks
paulele is offline   Reply With Quote
Old 12-29-2009, 07:29 AM   #2
Is it both hot and cold or just hot that smells?? Are you on a well??
Old 12-29-2009, 11:25 AM   #3
Rewards Points: 1,442
It probably came that way from the reservoir or well.
Much of Florida including Disney World has water with a sulphur (rotten egg) smell.
Old 12-29-2009, 10:28 PM   #4
city water
We have city water, the water on a outside tap line does not smell just the water on the inside. Both the hot and cold smell
Old 12-30-2009, 07:05 AM   #5
Not sure what to suggest, if an outside spigot does no have the problem, it obvioulsy is inside in the pipes. Water heaters sometimes have that problem due to the type of anode rod, but that would not affect the cold side. Where are you located??
Old 12-30-2009, 09:22 AM   #6
Civil Engineer
Rewards Points: 4,566
Rotten egg smell is usually associated with sulphur. Check with your water department, see if the public water supply has sulphur in it (occasionally it does). If the public water supply does not have a sulphur problem, you should start by getting your water tested by a chemical lab, have them check for sulphur, bacteria, and common metals. Once you know exactly what chemical is causing the problem, and you have determined the source (either the water supply or internal to the house), you can formulate a plan to treat it.
Daniel Holzman is online now   Reply With Quote
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
