Smell From Plumber's Putty - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2011, 10:17 AM   #1
Smell from Plumber's Putty
I recently installed two new polished brass drains in my bathroom sinks. Now, everytime I run water in these sinks, I get a strong smell of plumber's putty (which is what I used when installing the drains). Is there anyway to get rid of this smell other than taking the drains apart and starting over ?
peanutxyz is offline   Reply With Quote
Old 04-12-2011, 12:33 PM   #2
Exactly how long ago did you do the install? I do all my own plumbing and had a situation like yours and the smell eventually left after about 2 weeks. The only reason that there would be a smell would be that youhad some putty get inside the drain. if you dont want the smell lingering i suggest taking the pipe apart if possible and give them a good cleaning.
ahrens is offline   Reply With Quote
Old 04-12-2011, 12:59 PM   #3
Smell from plumber's putty
Installed the drains approx. eight weeks ago. Will try disassembling the trap and see what I find.
Old 04-15-2011, 03:56 PM   #4
Problem Solved
Ran a snake and cleaning solution through the drain and trap - no more smell. Thanks
Old 04-15-2011, 05:20 PM   #5
Good to hear. Glad ya didnt have to pull everything apart.
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Disposal torque removes plumbers putty cpowersr2 Plumbing 4 01-17-2011 08:46 PM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 09:19 PM
Clear Silicone instead of Plumbers Putty jmacx81 Plumbing 2 04-29-2009 07:14 AM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
