-   -   Smell from Plumber's Putty (http://www.diychatroom.com/f7/smell-plumbers-putty-101263/)
peanutxyz 04-12-2011 10:17 AM
I recently installed two new polished brass drains in my bathroom sinks. Now, everytime I run water in these sinks, I get a strong smell of plumber's putty (which is what I used when installing the drains). Is there anyway to get rid of this smell other than taking the drains apart and starting over ?
ahrens 04-12-2011 12:33 PM
Exactly how long ago did you do the install? I do all my own plumbing and had a situation like yours and the smell eventually left after about 2 weeks. The only reason that there would be a smell would be that youhad some putty get inside the drain. if you dont want the smell lingering i suggest taking the pipe apart if possible and give them a good cleaning.
peanutxyz 04-12-2011 12:59 PM
Smell from plumber's putty
Installed the drains approx. eight weeks ago. Will try disassembling the trap and see what I find.
peanutxyz 04-15-2011 03:56 PM
Problem Solved
Ran a snake and cleaning solution through the drain and trap - no more smell. Thanks
ahrens 04-15-2011 05:20 PM
Good to hear. Glad ya didnt have to pull everything apart.
