Smell Coming Out Of Sink In Laundry Room When I Use The Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2009, 10:14 AM   #1
smell coming out of sink in laundry room when I use the washer
I have a septic system and I want to know what I can put down the drain (and which drain should I put it down) to either clear a possible clog and/or get rid of the smell
precious is offline   Reply With Quote
Old 09-10-2009, 12:04 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
When was the last time you had your tank pumped out?
Also check to see that the drains have proper traps to prevent any gas coming back in.
You can also put a very heavy dose of bleach in your washer and set it on the soak cycle (extra large load with hot water for maximum water) overnight and start it to drain the next morning. This can be helpful, especially if you do a lot of cold water washes that never really clean out the system. Follow with a filling and draining of clean water.
Dick
concretemasonry is online now   Reply With Quote
Old 09-26-2009, 12:11 AM   #3
Make sure you dont let the sink sit a long time without running water to keep the P trap full of water. Without the water you will have gases come up through your drain pipes. Don't know if you already know that but just making sure
Daniel048225 is offline   Reply With Quote
Old 09-26-2009, 03:48 AM   #4
Joe F's Avatar
Rewards Points: 294
Is it a front loading washer? If so, it can be mold in the machine.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 09-26-2009, 07:37 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Never use caustic drain cleaners like Drano on partial clogs.
I always use a good non-caustic enzyme-based drain cleaner like DrainCare. It will eat out organic gunk overnight and then you just flush the line down with hot water to clear it. It won't harm fixtures or pipes.
As suggested, run water in your utility sink regularly to keep the trap filled. That's what traps are for, to prevent sewer gas from entering your home (doesn't matter whether it's sewer or septic system).
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-28-2009, 08:36 PM   #6
it could also be that when the washing machine is discharging that is pulling the trap seal. it would be possible if that laundry sink is not properly vented and on the same waste line
fhrace is offline   Reply With Quote
Old 09-29-2009, 10:58 AM   #7
Household Handyman
Rewards Points: 1,408
It's been a long time since I have seen one of these but--does your washing machine discharge hose dump straight into this sink? IF SO, and you state that this smell is only when the washing machine discharges water, could the problem actually be mold/mildew within the outer tub of the washing machine, as concretemasonry has suggested. Just another thought to help, David
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
Supply and Return from Laundry Room bjstewa HVAC 7 03-02-2007 11:39 PM
Sewer gas smell in basement when doing laundry on main floor Bornintc Plumbing 1 01-17-2007 11:04 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
stabilizing floor in laundry room waterlily_girl Carpentry 3 03-02-2006 12:59 PM
