Old 07-30-2010, 08:30 PM   #1
Small Tank or High Overflow Tube?
Hi All...
I just purchased a hydroclean fill valve for my toilet. The critical level line is "required" to be 1" above the top of the overflow tube. Either my tank is short or my tube is high but I am unable to adjust the new fill valve to this height without breaching the top of the tank. Can I cut the overflow tube down to size? Any other suggestions? Thanks
RT
Rubbertree is offline   Reply With Quote
Old 07-30-2010, 10:56 PM   #2
Owner
LateralConcepts's Avatar
Instead of cutting it; possibly damaging it's functionality, maybe return it and purchase an adjustable Fluidmaster?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 07-31-2010, 12:38 AM   #3
nap
You talking to me?
nap's Avatar
if you cut the tube, would you have to lower the water level which would of course reduce the amount of water in the tank which could affect the quality of the flush?
Old 07-31-2010, 08:52 AM   #4
Yes I would have to lower the water level. I'll check out the fluidmaster today but the hydroclean is adjustable too so I don't know where I'll stand at the end. Thanks for the suggestions.
RT
Tags
hydroclean, overflow
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Flooded Salt Tank in Kenmore H2O Softener whitedavidp Plumbing 2 01-07-2010 01:05 PM
My Septic drainfield must be filled with roots, what do I do? BJLower Plumbing 1 04-25-2009 02:22 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
