Small Manhole Cover For Sewer Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2010, 10:41 PM   #1
Small Manhole Cover for sewer cleanout
My sewer cleanout is right where i park so i have had to replace the PVC cap twice. I just wanted to know if there was some sort of small manhole i could install to make this safe for me to park on so i dont cause any more extensive damage. Also if there is such a thing, what would it be called and where could i purchase it?
Thanks in advance:
nbige is offline   Reply With Quote
Old 06-21-2010, 11:12 PM   #2
Rewards Points: 152
We use something like this in our municipality, we call it a brooks box
http://www.brooksproductsnw.com/pb.html
Any distributor that sells sewer or water pipe for a municipal application should carry it, your local plumbing supply might be able to bring it in too. If no luck, call up the local sewer dept and see where they get theirs.
burnt03 is offline   Reply With Quote
Old 06-21-2010, 11:13 PM   #3
Rewards Points: 152
Old 06-21-2010, 11:17 PM   #4
Owner
LateralConcepts's Avatar
Thanks in advance:
Check Sioux Chief for a traffic grade cast iron cleanout. Depending on the size of pipe, how tight the concrete/asphalt is to it, you might need to chip some out to fix it.
http://siouxchief.com/Drainage/Comme...nage/Cleanouts
Also if the riser is tight in the concrete you might be able to just flip a PVC cap over so the square nut isn't sticking up in your driveway. Then you just need to build yourself a square tool to tighten and loosen. Tool would look like a branding iron with an "X" the right size on the end of a T handle.
LateralConcepts is offline   Reply With Quote
Old 06-21-2010, 11:29 PM   #5
Owner
This would also minimize the damage to your cleanout cap... haha
http://www.happyscooters.com/150cc-C...ter-p-440.html
Old 06-22-2010, 09:06 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They make small concrete ~8" round boxes with heavy iron lids too. That rectangular box looks a little big...
Journeyman Plumber
Tags
drain box , manhole , outdoor plumbing , plumbing
Small screwless cover plates? secutanudu Electrical 22 05-27-2010 08:24 AM
Re-using a drain cleanout mpt1123 Plumbing 0 01-19-2010 05:45 AM
small simple flat roof to cover an outside bar 60yroldnovice Roofing/Siding 1 09-09-2009 04:21 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
