01-20-2010, 09:31 PM
#1
small bathroom rough-in, see anything wrong?
Hi,
I just completed a small bathroom rough-in and before I cement and crimp everything together I thought I'd post a few pictures of it and see if anyone saw anything wrong with my work.
I've used two inch ABS for all the vents and drains. They run into a 3 inch pipe that runs into a 3 inch stack to the basement.
there is a toilet on the first floor below that is wet vented by the stack i've run everything into on the second.
everything is sloped atleast a 1/4 inch per foot down stream.
I've used pex piping to run the hot and cold to the fixtures and rent the pex crimp tool and crimp them altogether when i've heard enough people say i'm good to go.
Thanks for any advice or constructive criticizm.
01-20-2010, 09:34 PM
#2
more pictures
01-21-2010, 07:27 AM
#3
I'm no plumber but looks ok to me. I did notice a corrugated plastic 4" vent tube running in one of your pictures. If for a dryer, most say it should be replaced with metal for fire issues. Not sure what kind of screws you used to anchor your brasswork, I'd used something other than drywall screws if they were used. Might want to secure water supply lines to joists every so often to prevent noise if they start moving around. Good luck with your project.
01-21-2010, 09:10 AM
#4
Be sure your toilet flange is 12" from where your finished wall will be for a 12" rough toilet. Often us DIYer's forget the finished wall is the reference point, not the framing to allow for different wall material and finishes. For 1/2 drywall I go 13" from the framing. It gives me a little fudge factor and often allows painting w/o removing the toilet in the future. It looks like your tub and sink traps are pretty much set with no adjustment. I don't see how that will work. I have always used a desanko or slip joint adapter (what ever you call them in that part of the country) for the sink so you can use a standard 1 1/2" p-trap with a 1 1/4" adapter for a typical vanity sink drain. For the tub I set the trap after the tub is installed. Of course I can't measure what you have but I don't see how a waste and overflow will fit a typical tub where your abs comes out of the floor.
It might be an optical illusion but I think your vents are sloped the wrong way. IT probably will not hurt anything if that is the case.
Rege
01-21-2010, 10:07 AM
#5
A "Handy Husband"
I would not use PEX for the tub fill spout, the smaller size can cause the shower to dribble while you fill the tub. Use copper tube or brass pipe for the tub fill leg.
Coastal South Carolina
01-21-2010, 03:17 PM
#6
Thanks for the advice so far
Those were drywall screws I'll change them out.
The toilet flange is 12.5" out from the framed wall but maybe 13 " would be better. I'll try and find those slip or adjustable ptraps like were mentioned. apparently the tub we are getting has a built in overflow, so you only need 1 drain.
someone else mentioned the thing about the fill spout and using pex I will replace it with a brass tube.
Thanks for all your comments. Very helpful.
All the vents slope towards the stack.
01-21-2010, 03:34 PM
#7
Rege
Good eyes Rege, drains fall and vents rise
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
01-21-2010, 03:48 PM
#8
All vents are wrong, they slope the wrong way. All Wyes are installed reversed too. You want the air to rise as it travels to the vent stack, not fall.
01-21-2010, 06:02 PM
#9
Remodeler
Yes, try to slope the horizontal run of the vent pipe upward toward the stack. The tees that connect the vertical runs of vent to the horizontal run are reversed. Also, I can't see it really well, but it looks like the tee that connects horizontal run of the sink drain to the vertical wet vent/drain is upside down/reversed. That needs to be so that the water will flow down the tee into the drain; it looks like the tee is situated so the water would try to flow upward. Otherwise, a good layout overall. You may have wanted to leave a little extra space from the framing to the toilet drain; 12.5" is cutting it really close. But you should be okay.
01-22-2010, 04:34 PM
#10
Be sure yor toilet fill line is close enough to the toilet inlet.I think most toilets fill on the other side.
01-22-2010, 09:11 PM
#11
It could be just the picture but on picture #814 are you missing one of the compression rings on the pex?
01-23-2010, 12:49 AM
#12
retired elect/hvac/plumb
santees on vents are backwards,your horizontal vent line is pointed down on the end to tie into vent stack,should be pointed up where it ties into vent otherwise air goes down stack then has to go back up around a corner the way you have it.on your waste line under floor you have santees laid on back,which is ilegal around here anyway should be wyes instead .ill let somebody else have at ya now!
01-23-2010, 08:52 PM
#13
i wouldve run the arm for tub drain/trap under joist instead of blowing that big hole in there,id beef that joist up
01-24-2010, 09:20 AM
#14
A "Handy Husband"
You have a vinyl flexible vent run under the floor. I would replace with a solid metal vent (aluminum or galvanized).
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
