Small Amount Of Rusty Water.Please....help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2011, 09:48 AM   #1
bsa_bob
Rewards Points: 150
Question
Small amount of rusty water.Please....help
I recently installed cleaned and and installed new salt. My salt brine barrel had bridged,Repaird,and cleaned it all out good it and had great;....... rust free water for two days.I am back where i started. Can anyone share with me what i should do next,I set the time on the white dials on top.......................I bumped the smaller set of dials in the lower corner, and they turned a little bit.These are the dials that say how many gallons of water to salt etc.
I am a retired plumber but never had a softener before ,Is there a filter or something that i can"t see that needs checking?/There is a paper clip that has one leg bent strait, it was used for something?? before, cause it is corroded from laying there[on top of cut=off]
bsa_bob is offline   Reply With Quote
Old 03-22-2011, 11:48 AM   #2
Rewards Points: 104
Bob, have you checked your water heater, in order to eliminate it as a culprit? Also, there may be cases where they are not required, but in my area, SE MI, virtually every softener has a prefilter, and I have seen those without have shotened lives. I have always felt too that it is worth while to have the water tested before purchasing a filter, because although general purpose ones are readily available, you may see something specific in a test that you would lead to a specific filter. As for you specific softener, someone may be able to answer in general terms, but I would suggest that you locate a manual for it, as perhaps your cycles are not as they should be, or futher maintenance is required.
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 09:42 AM
I want to pour a small slab... Any pointers? Alan Building & Construction 2 04-17-2010 05:46 PM
Kerdi-band: where can I purchase with reasonable shipping? (Need small amount) lazzlazz Kitchen & Bath Remodeling 1 04-17-2010 11:58 AM
Small, very small bathroom exhaust fan stubits HVAC 3 04-06-2010 01:52 PM
Curved Small Stage jalaux Carpentry 1 07-09-2006 09:57 PM
