Slow Upstairs Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2011, 01:30 PM   #1
slow upstairs sink drain
OK, bit of a problem. I have a master bath sink drain that has started to drain very slowly. I have removed the P trap and the drain plunger to make sure everything is clear. some hair fell out of the trap and when i turn the water on it clearly runs into the bucket. I put everything back and turn the water on and again when the trap fill with water it again drains slowly.
Any ideas?
mxcrazy is offline   Reply With Quote
Old 07-23-2011, 05:21 PM   #2
Did you check between the trap and where it drains into the stack?
VIPlumber is offline   Reply With Quote
Old 07-23-2011, 09:24 PM   #3
I guess I'll have to buy a snake unless there is another way to do it.
Old 07-23-2011, 10:16 PM   #4
Use a flashlight first, maybe you could get away with using a wire coat hanger if you can't see the dip/bend towards the stack. And if the distance isn't too far.
Rerouted Under Sink Drain for Disposer gilbo125 Plumbing 5 01-24-2011 08:35 PM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 09:52 AM
Maximum distance of sink from drain? DIYHomeTheater Plumbing 0 06-14-2010 07:42 PM
Slow kitchen drain - tried almost everything! Critical Mass Plumbing 17 07-15-2009 07:57 AM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
