-   -   slow upstairs sink drain (http://www.diychatroom.com/f7/slow-upstairs-sink-drain-111723/)
mxcrazy 07-23-2011 01:30 PM
OK, bit of a problem. I have a master bath sink drain that has started to drain very slowly. I have removed the P trap and the drain plunger to make sure everything is clear. some hair fell out of the trap and when i turn the water on it clearly runs into the bucket. I put everything back and turn the water on and again when the trap fill with water it again drains slowly.
Any ideas?
VIPlumber 07-23-2011 05:21 PM
Did you check between the trap and where it drains into the stack?
mxcrazy 07-23-2011 09:24 PM
I guess I'll have to buy a snake unless there is another way to do it.
VIPlumber 07-23-2011 10:16 PM
Use a flashlight first, maybe you could get away with using a wire coat hanger if you can't see the dip/bend towards the stack. And if the distance isn't too far.
