Slow Tub Drain, New Tub Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2013, 12:27 PM   #16
Rewards Points: 27
It's probably just the design of the outlet and plug that does not allow
water to drain as rapidly as your old setup. As long as it can flow 2.5
gal/min to keep up with the shower head output (if there is one), there is
really no need for more, and it's not clear why you're so concerned about
this.
kreemoweet is offline   Reply With Quote
Old 01-11-2013, 01:00 PM   #17
Roofmaster
Rewards Points: 2,172
Im with Weet.
Being the cheapo that I am, or more accurately, Not being able to comprehend the thought of spending $139 on a tub drain assembly (Kohler) I installed one of the same sets you did on my jacuzzi tub.
They are as slow as molasses in January. Its the nature of the beast. I suspect there is nothing wrong with your drain.
I was going to replace mine, but I figured, once I lift the popup why am I standing there watching the paint dry? Who cares if it takes a while to drain. We ain't talking solid waste here. (At least I know I don't do that in the tub) Accidents excepted.
Old 01-12-2013, 10:13 AM   #18
That is an interesting possibility, and one I hadn't considered. In my investigating, I did notice that the opening between where the drain screws in and the 1 1/2" pipe itself was somewhat small. The fact that you had the same issue with the same drain kit helps. However, while I haven't paced it with a stopwatch, I think the rate of draning is closer to 1 GPM than 2.5. But your post has me thinking I should try a different drain if I can't find anything specific.
Thanks!
eshock is offline   Reply With Quote
Old 01-13-2013, 01:02 PM   #19
Well.....
I dropped the drain today and immediately discovered the problem. Due to the length of the overflow in the new tub, we had to add a small extension piece between the T and the opening for the overflow. Yeah, you probably know where this is going... we had assumed that the piece snugged up inside on a stop, before obstructing the drain, but it of course, it didn't. A quick job with a hacksaw to shorten the extension, and the drain works beautifully.
Thanks to everyone for their input. I hadn't mentioned the extension piece previously, because I didn't think it could be a factor. As the two old sayings go, "its always in the last place you look" and "ASSUME: ASS out of U and ME." Lesson learned, and thanks again.
-Eric
The Following User Says Thank You to eshock For This Useful Post:
oh'mike (01-13-2013)
Old 01-13-2013, 01:04 PM   #20
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
Thanks for the feedback.....with luck it will save someone else making the same mistake....
BTW...I bet it feels good to get it fixed. How much faster is the draining now?
Old 01-13-2013, 03:26 PM   #21
DIY staff
Rewards Points: 7,174
Thanks for the news---I've seen that when a P-trap is shoved to deep into a wall and 'bottomed out' inside the T----
Old 01-13-2013, 03:46 PM   #22
Roofmaster
Geez, I wonder If I did the same thing???? If it can be buggered, I probably bugged. Makes you feel lile a Noob dont it? Glad you solved it and let us know about it.
The Following User Says Thank You to jagans For This Useful Post:
oh'mike (01-14-2013)
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 10:24 AM
Water drain out slow in sink nhoj Plumbing 5 10-27-2012 02:08 PM
Reoccuring slow tub drain jmorc2003 Plumbing 8 10-20-2012 06:42 PM
Drain In Bathroom Sink Drains Slow nhoj Plumbing 4 06-24-2012 07:09 PM
Slow kitchen drain - tried almost everything! Critical Mass Plumbing 17 07-15-2009 08:57 AM
